GrantG's Avatar
Camshaft for Street/Track 3.2SS
I'd be interested in any suggestions for camshafts for the following motor:
3.2 SS (3.0SC case & crank with 98mm JE Pistons & Mahle jugs)
10.5:1 CR
Twin-Plug Ignition
SSI Heat Exchangers w/ Factory-style Dual-Out muffler
50mm PMO's (planning to use smaller venturis - suggestions welcome)
Carrera 3.2 Heads (Intake ports 41mm, Exhaust 38mm expanding to 41mm at exit)
Carrillo Rods & Aase valve springs with Ti retainers
Short and Close Custom gear ratios in gearbox
Desired peak power somewhere around 6,500rpm with 7,200 max revs and wide power band
Lightweight car (<2,000 pounds)
High Altitude (5,000ft and higher)
I am not looking for max hp (I know the exhaust is a bottleneck, but I want heat in Denver and quiet enough for morning drives) - I want a flexible motor that will still get the "on the cam" feeling and rush towards redline.
One cam I am considering is the Elgin 306/288 - any thoughts?
Note: Engine is already built, so please consider the above parts "locked in".
Thanks!
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 08-03-2011, 09:48 PM
I have a 3.0 with 95mm 10.5 : 1 JE, twin plug with 28 degrees of timing, 46mm Webers and headers with muffler. I run a GE60 cam. Power starts at about 4500 and pulls hard to 7200 and then signs off. Below 4500 it runs like a stocker, idles nicely and is easy to drive on the street. No dyno numbers but an experienced "butt" dyno says 265 - 275 hp at the wheels.
Since the max lift is less than .500 and the ramp is easy, this cam is pretty easy on the valve train.
Tell it like it is or don't tell it at all.
Old 08-04-2011, 06:58 AM
GrantG's Avatar
Thanks!
Old 08-04-2011, 07:04 AM
BURN-BROS's Avatar
DC60 or DC62. I recommend DR racing cams.
street 36-38mm vernturi...you will need to decide what compromise suits you
track 44mm venturi or so.
jetting will be different between both venturis
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-04-2011, 07:58 AM
