metric and LAN fittings
hello
I was ready to install my 69T/E engine I just rebuilt, I was wanting to get stainless steel lines for the main and cooler lines, I can't find fittings to convert the 911's metric fittings to AN, does anyone have a good place to shop for fittings? Also what size AN lines would you folks recommend for the 69T/E with no front cooler thanks Dave |
Earl's can make lines with AN or Metric fittings...
-Wayne |
-12an should be fine for a 2.2.
Clewett makes a -12 adapter for the case, Pegasus makes the 30mm to -12 oil tank/thermostat adapters. Havent checked the pelican catalog so I dont know if they have these type fittings. |
| All times are GMT -8. The time now is 04:23 AM. |
