-   -   timing chain (http://forums.pelicanparts.com/911-engine-rebuilding-forum/121273-timing-chain.html)
ferry_pp 07-30-2003 11:34 AM
timing chain
Hi,
Rebuilding my 2.4T engine.
Is it normal that the chain ramps on the left side of the engine are not pushed as far back on the support bolts as on the right side?
Thanks,
Philip
Belgium
Wayne 962 07-31-2003 02:10 AM
Off the top of my head, the bolts are the same for the left and the right, or are you talking about the ramps in the housings?
-Wayne
ferry_pp 07-31-2003 02:29 AM
The 4 ramps (2 black left, 1 black-1 brown right) inside the engine case.
The bolts are the same, but on the right side the end of the bolts sticks out further through the ramps.
Or to put it another way: On the right, the side of the ramps is touching the engine case. On the left not.
Philip
Tim L 07-31-2003 07:29 AM
If I remember correctly the ramps snap into a grove on the bolts and should be the same.
Tim
Wayne 962 07-31-2003 12:23 PM
Are we talking a milimeter, or larger distances? The pics in my book seem to indicate that they are about the same distance. They are turned around 180 degrees, so they might look slightly different when mounted.
-Wayne
ferry_pp 08-01-2003 12:17 AM
I'll send you a pic.
Wayne 962 08-01-2003 11:42 AM
Post the pic here...
-Wayne
ferry_pp 08-07-2003 02:06 AM
Problem solved. The aligment became obvious when installing the outer chain supports and camshaft sprockets. It seems the right side was pushed too far back on the support bolts.
By the way, I was really confused about the cam timing. Overlap at TDC and actual opening time in ° before TDC did not match. Until I say the footnote that timing is measured with 1 mm clearance...
Philip
Wayne 962 08-07-2003 02:08 AM
Got the engine book?
-Wayne
ferry_pp 08-07-2003 02:16 AM
Yep,
Two actually. The second one came together with the bonus Cd rom I ordered???
That footnote should be in red and flashing...
Otherwise really great book!
Philip
