Lee Lee is offline
max moritz pistons
Some guy called Uncle Zak has a set of Max Moritz pistons for sale on eBay. I think the sale ends in two days or so.
He wants $700 for a buy it now, but that seems kind of steep for sight-unseen used pistons, with "light mileage" even if they are the fabled Max Moritz. I bid $300, and it didn't get me anywhere. Could anyone give me an approximate value of these?
Another question: if I were to buy a set of used 3.2 pistons, and combine them with a 964 cam, and an early 911 exhaust, would this come close to the Max Moritz stuff?
Thanks.
Daniel Crockett
Daniel Crockett
'78 SC Targa
Old 08-02-2003, 07:01 PM
Author of "101 Projects"
Wayne 962's Avatar
You need one of these: http://www.101projects.com before you start bidding on eBay. Don't mean to sound condescending, but it's true.
Case in point: regular 3.2 pistons and cylinders will not work with your 3.0L (these pistons on eBay will though). You need to make sure that you get the specific big bore pistons that will work with the 3.0L crank. I just picked up a set of these last month (last set in the states) for $3600 (retail).
You can use the standard 3.2 cylinders with these pistons and your 3.0L crank.
Another option would be to have custom pistons made by JE, replicas of these. The cost for these JE pistons would probably be around $1000 or a little more (don't know the costs). Used cylinders would be about $800 or so, depending upon condition...
Zak has a pretty good rep on this BBS, ask him about the ring groove measurements (if you had the book, you'd know which questions to ask) and ovality.
Another thing to keep in mind (also in the book) is that these pistons will not work with the 964 cams or your CIS cams and fuel injection. You need to replace your fuel injection...
-Wayne
Old 08-02-2003, 09:33 PM
Hilbilly Deluxe
emcon5's Avatar
I don't know if they are the same ones, the Ebay ad isn't very detailed, but Unclezac bought the set I was selling here:
Mahle 98mm Max Moritz pistons for SC
The pink bubble-wrap looks familiar though.
Tom
82 911SC Coupe
GTI Cup #43
Old 08-04-2003, 07:43 AM
LakeCleElum's Avatar
Originally Posted by Wayne at Pelican Parts View Post
You need one of these: 101 Projects Website before you start bidding on eBay. Don't mean to sound condescending, but it's true.
-Wayne
I have a set of 3.2 Max Moritz Pistons in a 3.0 that is in my 73.5.....Runs great with CIS....209 RWHP....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 08-11-2014, 03:30 PM
toddu's Avatar
Ummm, you realize this thread is 11 years old. ;-)
Old 08-11-2014, 03:56 PM
3 restos WIP = psycho
kenikh's Avatar
And even has an Uncle Zak reference!!!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-25-2014, 07:49 PM
Kartoffelkopf
Spenny_b's Avatar
Ok, now I'm intrigued (as a relative newcomer to PP)...do tell?
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 08-28-2014, 02:58 PM
