-   -   Getting the Scaley build-up off of the exhaust valves? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/121793-getting-scaley-build-up-off-exhaust-valves.html)
jluetjen 08-03-2003 01:41 PM
OK, I've been spending some time today cleaning up the heads which will ultimately be going into my my 2.2 race motor. Almost all of the exhaust valves have a scaley build-up on them that seems pretty impervious to a wire brush attachment on a drill. For comparison, the drill and brush seems to work great on the heads themselves. Some of the valves (from a different set of heads) have some really nasty black build-up. On one of them I tried using a gasket scraper to scrape the stuff off, but that is pretty slow going and dulls the scraper.
What's the best way to get the stuff off?
911pcars 08-03-2003 02:48 PM
You can try soaking them in carb cleaner for a day or so.
Sherwood Lee
http://members.rennlist.org/911pcars
Wayne 962 08-03-2003 10:26 PM
Bead blaster at the machine shop?
-Wayne
Early_S_Man 08-03-2003 10:34 PM
Leave them overnight, or for a day or so in a can of Berryman's Chem-Dip ... the build-up will come off very easily! A popsicle stick will be all you need to scrape them with ...
jluetjen 08-04-2003 04:46 AM
Thanks! SmileWavy
zephog 08-06-2003 05:44 AM
Soak them in a 2 liter pepsi overnight. Wonder what that stuff does to my stomach
beepbeep 08-08-2003 08:00 AM
Heheheh... it's frightening that it actually works!
911pcars 08-08-2003 10:44 PM
Try soaking a hunk of beef in coke or pepsi for a day or so and see what happens to it.
BTW, if you use Pepsi for your valves, is this then recyclable as a refreshment (as long as it's cold and still has fizz)?
Sherwood
snowman 08-10-2003 11:44 PM
Bead blasting works, but CAUTION!!!! glass beads leave stuff behind. That stuff can do in an engine. If you bead blast, clean, brush, brush and brush again to remove any remnants of the beads.
NEVER bead blast a case. You cannot ever get all, ALL, the beads out. Beads are the top cause of engine failure on a rebuild. Thats per one of the top engine machinest magazines for engine rebuilders.
