Question Woodruff key on altenator?
83SC Euro
I pulled my fan off the altenator shaft to clean it up.
I found a slot in the bore of the fan and a round slot in the shaft of the altenator.
No Woodruff Key.
I don't thik it was there.
I looked on PP site and couldn't find it.
I called PP and they couldn't find a number for it.
I looked on my Pet5 software and couldn't find it.
I recall reading that the fan is pressed on.
I used a self made 2 bolt puller w/6mm bolts. It came off fairly easily.
Is it possible that they omitted the key for some reason.
I'm pretty sure that when you tighten the fan belt nut that it's tight enought to keep the shaft from spinning in the bore.
There was no evidence that it was spinning.
Anybody know about this?
I found some key's at the hardware store that I'm going to try.
No metric, but one might work.
Old 08-27-2003, 11:26 AM
Author of "101 Projects"
Wayne 962's Avatar
I'm 99% sure that there should be a woodruff key in there - it is probably considered a part of the alternator, that is why there is no Porsche part #. Look at this page:
http://www.pelicanparts.com/techarticles/tom_sharpes/911_engine_comp3.htm
-Wayne
Old 08-27-2003, 01:18 PM
ValveFloat's Avatar
Mine used the same key as the cams. Not sure if the SC would use the same key.
Joe
1993 C2
Old 08-27-2003, 04:36 PM
Super Moderator
cstreit's Avatar
Yes there is a key, or should be. I found one at Ace hardware when I dropped mine on the garage floor and it disappeared
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-27-2003, 05:49 PM
ejm914's Avatar
PET shows keyway p/n 900 118 006 00 (4 X 6.5) for thru '77 and keyway p/n 999 118 008 00 (size ?) for '84 + up. The technical reference catalog shows the same alternator p/n fitting '75 thru '83. So I would think you need the earlier keyway.
Old 08-28-2003, 06:48 PM
ejm914's Avatar
It's page 105-00 when looked up for as '77 or '84. It's not pictured, it's an unkeyed part number in the listing.
Old 08-28-2003, 07:19 PM
Thanks for solving the mystery.
I looked this up and saw it on Pet as well. I looked at the cam ke as was mentioned above. It's 4X5.
How are these measured. I'm assuming the 4 is the width. 5 or 6.5 must be the height since the length would be much more.
I think I found my missing key. I bought an assortment of about 4-5 at the hardware. They were english spec. They were listed by width and length. When I got home I dumped them out on the part's tray. (Actually a Plano fishing lure box.) I tried one, the width, thickness was perfect but too long and tall. Found a shorter one worked well. Then I found a dirty one in the pile. (I must have removed the fan off the altenator above this parts box and it dropped into the box!)
Now that I have the right size , provided above, I can be certain.
Thanks!
It's also good to know that the hardware store version would probably work fine in a pinch.
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 09-02-2003, 01:03 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
William,
I have a spare key. I'll bring it over tonight when I return your tools.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 09-02-2003, 01:23 PM
