-   -   carrera chain tensioner (http://forums.pelicanparts.com/911-engine-rebuilding-forum/122344-carrera-chain-tensioner.html)
ferry_pp 08-07-2003 01:50 AM
Hi,
I'm rebuilding my 72 2.4 T engine. With carrera chain tensioner upgrade off course. My question concerns the mounting of idlers and tensioners on the chain housing shaft.
On the left side the idler arm fits against the chain housing and the chain tensioner fits against the idler arm. Looks OK.
On the right side however, the tensioner fits against the idler but there is a gap between the idler arm and the housing.
Should there be a spacer between the housing and the idler arm? Any comments?
Oh yeah, the idler arms are the later style.
Thanks,
Philip
Belgium
Wayne 962 08-07-2003 02:09 AM
How big is the gap? A small gap is normal. A large gap of about 1cm is what you typically see when you install the newer style tensioners with the older-style idler arms.
-Wayne
ferry_pp 08-07-2003 02:33 AM
http://forums.pelicanparts.com/uploa...1060248794.jpg
The gap is about 3mm I guess.
Wayne 962 08-07-2003 04:07 AM
That sounds normal. Compare it to the photos in Chapter 5 of the Engine Rebuild Book...
-Wayne
