-   -   Are the wavy washers the best? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/122737-wavy-washers-best.html)
Zeke 08-09-2003 08:30 PM
Where wavy washers come off the engine on some studs, should they be replaced with new each time? Are they the best? I know a lock washer against an aluminum or mag case is not the proper use of that kind of washer. So, is there something better?
911pcars 08-09-2003 08:54 PM
The steel wave washers should be good for a long time. I'd reuse them.
Sherwood Lee
http://members.rennlist.org/911pcars
snowman 08-10-2003 10:39 PM
OR use nylocks. But on the inside, I still choose to use wave washers. No good reason, just because.
