Author of "101 Projects"
Wayne 962's Avatar
Owner's Exemption: 911 Carrera RS 2.7 Throttle Bodies & Stacks...For Sale...
Super rare - you know the deal. If you're looking at this post, then you know. I have these up for auction right now on eBay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=33558&item=2427446932
Please read the description there, and look at the 100 photos I have posted.
The last time that I saw a set of these, I actually had them:
911 2.7 RS MFI System NEW/Rebuilt For Sale
Also note the following:
"Although there has been some speculation on this subject over the years, I have Porsche factory documentation from 1973 that clearly shows the 911 Carrera RS stacks and throttle bodies listed in parts books (see pictures below). According to this factory literature, the Carrera RS stacks and throttle bodies were the same ones used on the 2.4 911S. So, these stacks and throttle bodies should be interchangeable among the two with absolutely no performance degradation. For reference, the part number for the stacks is 911.110.063.02. These are interchangeable from left to right. The part numbers for the throttle bodies are 911.110.085.10 and 911.110.1085.11. These indeed are the 911RS / 911 2.4S throttle bodies, and their dimensions match up as well (see photos). The intake on the bottom of the stacks is 38mm, which matches the top intake dimension on the throttle bodies, which is also 38mm. The outlet dimension of the throttle bodies is 36mm, which matches the 36mm intake ports found on the 911 Carrera RS and the 911 2.4S."
-Wayne
Old 08-09-2003, 05:32 PM
