-   -   Race motor *major* Hand-Grenade - doing forensics & need help. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/123820-race-motor-major-hand-grenade-doing-forensics-need-help.html)
jeffstev 08-17-2003 08:57 PM
My new 3.4L race motor blew up while on track at Fontana - a complete loss. I'm doing the forensics on it right now. It appears that the wrist pin failed on the JE piston at about 8000rpm and caused a chain reaction - basically it's a complete loss. Looking at the Motec log file, everything appeared normal right up until the hand grenade. the wrist pin bushings look normal but the rod bearings are a bit worn. This new motor had a total of about 6 hours on it when this happened.
full story and pics are here:
http://www.bushwackerracing.com/blowup_index.html
http://forums.pelicanparts.com/uploa...1061178939.jpg
What doesn't make sense is the damage that happened to the right lower chain ramp. I am only guessing but it appears that ramp in question was about to fail anyway - there's no way it could have failed as a result of the blowup because cyl #3 hand grenaded (left bank) and the right lower chain ramp is the one in question. Looking at Motec it tells me that 2.5 seconds elapsed from the time the motor blew to the time I had 0 revs - not enough time to create this kind of damage to the tensioner AND have all the filings work their way down and into to the oil pump mesh.
I seem to recall pulling the tensioner out of the bottom and looking at the markings on it which said "Links" which means left in German. Is it even possible to put these tensioners in reversed (this is a late model 993 motor)? And if they were reversed, would it make sense that this type of damage to the ramp would occur? There was also a ****load of plastic debris stuck in the bottom of the oil pickup mesh which might explain an oiling problem - all of the rockers were pitted and are now useless.
http://forums.pelicanparts.com/uploa...1061178751.jpg
If anyone has comments/ideas, let's hear them.
I'm also looking for 3.2 parts - I need to start over and it looks like a 3.4L motor based on a 3.2 case is the best way to go right now. Basically I need EVERYTHING. What do you have that I can use?
Jeff
snowman 08-17-2003 09:04 PM
Wrist pin failure?????
just looked at your pictures
COOL MAN!!!!
Lovely pictures. Those rods really looked nice before they were bent up so much.
On a more helpful note, What were a whole bunch of things before it blew up? ie piston to head clearence, valve to piston clearences, did you measure EVERY one? How high did it REALLY rev? do you have anything concrete or just drivers memory?
Take the rods apart. any excessive clearence? any scoring? or signs of lack of oil? What do all the piston tops look like? The pitting in the rockers is bothersome. What does the cam look like? take many more good pictures and maybe there will be a teltale sign somewhere. the broken wp, is it scored? Did you check valve spring bind? How much clearence did you have? What about the valve springs, any broken? Did you check all the spring pressures? if so how much?
The thing that is most suspisious at this point, not having all the information, is the pitting in the valve followers. How and why is it there?
With the additonal problem with the seemingly non connnected chain guide, I would strongly suspect a valve train problem(s).
jeffstev 08-17-2003 09:19 PM
Don't think you'd be saying "COOL" if it was your motor...
snowman 08-17-2003 09:31 PM
Yes I would say cool. Been there done that (non Porsche motor though).
ChrisBennet 08-17-2003 09:35 PM
That so, soo sucks. My condolences.
-Chris
911pcars 08-17-2003 10:56 PM
You obviously have much work and heart in this project. That sucks. Sorry to hear (and see) the aftermath. One might think that's one of the chances one takes when racing, but still, when it happens, it's disheartening.
The pitted rocker arms might be an independent incident. How's the cam lobe side of things? The broken valve head looked fairly healthy. Though I suppose should be as it's going up against mere aluminum. The broken valve might have been the beginning point of the big bang or perhaps a faulty wrist pin boss. How many hours on this 8000 rpm engine? What was the expected life expectancy? What's the weight comparison between JE and equivalent Mahle pistons? Perhaps others with more engine failure experience can contribute.
If forensics doesn't reveal anything concrete, all you can do is check and recheck, magnaflux and Zyglo until you're satisfied everything is the way it should be during assembly.
Sorry couldn't help more,
Sherwood Lee
http://members.rennlist.org/911pcars
350HP930 08-17-2003 11:23 PM
I'm assuming that a 3.4 liter motor has a 2.75" or greater stroke, correct?
That being the case 8K RPM would seem to be an excessive RPM for the piston and rod assembly.
Does JE even recommend using those pistons at that high of an RPM?
Even in a race motor there are still limits to the strengths of aluminum and steel.
jeffstev 08-17-2003 11:29 PM
All good questions and since I didn't do the assembly, I can only answer what I know for sure:
69.4mm destroked 3.0L crank. 102mm pistons. This is a "short stroke/over square" motor - high revs are supposed to be possible. JE was consulted on the motor design.
Revs: honestly, 8200 was the rev limit, and I rarely visited that spot. About 6 hours total on the motor, including idling, dyno, etc.
Piston Tops - there are signs that valves were coming VERY close to the valve pockets, based on the shadow of the exhaust gas left in the top of the piston. No "scoring" but you can see a perfectly round shadow on several of the pistons in the exhaust pocket.
Cams: lobes are perfect. I've had this problem before w/ the rockers - it was a problem with the oil squirters the last time. we changed them to the early style and got rid of the 993 ones which restrict the oil flow.
Wristpin: it's a mess from the explosion but you can see in the picture that it is actually very clean and was fine right up until it was hurled out the top of the motor. The final test on this was looking at the wristpin bushing which looks perfect - no scoring or discoloration on either surface. all rod bearings looked ok although there were some signs of wear. Journal sizes were close to within spec on the failed rod - 53.0mm but my micrometer isn't perfect.
And re: the valvetrain - my question remains - is it possible to interchange the chain ramp tensioners on a 964/993 motor?
Jeff
TimT 08-18-2003 03:03 PM
Ive seen a similar failure in a high compression 3.4 race engine, also with JE pistons. The engine I saw that had a failure like this was based on a 3.2L case, 8000 rpm redline etc.
We determined that there wasnt enough head/piston/valve clearance. One of the pistons pounded the head enough that it fractured, The piston skirt broke away, the rod pulled from the piston. And we had a pic that looks kinda like yours. It sucks when its a total loss..
This engine also had low hours on it... so figure a JE can last about 6 hours pounding the head till it fails....Its not the wrist pin that fails, its the piston that ends up cracking.... and then all hell breaks loose..
dont know about the chain ramp..
john walker's workshop 08-18-2003 07:21 PM
was the valve spring broken? i just tore down a 3.6 hot rod that must have run with a broken spring long enough to pull the keepers thru the retainer, resulting in the valve head getting bent sideways by the piston, and breaking off, punching a hole in the piston and bending the rod. luckily on decel @ 3500. i was going to use J&Es on the rebuild. now you're scaring me.
juan ruiz 08-19-2003 05:25 PM
That REALLY REALLY REALLY SUCKS BIG TIME! BUT guys when I did my research I have hear at least 15 different hand grenades ALL of them with JE Pistons coincidence ? Im not sure but I did stay away just for the fear.
TimT 08-19-2003 07:19 PM
John, Juan....... dont dismiss the JE pistons
I have them in two of my cars. One of which is a 7800 rpm engine..My 2.2 is a high compression zero clearance engine..no problems with piston failure. We have engines that have been in service many years using JE's
My 914 is tame at about 9.3:1..........
Juan my friends monster turbo engine making over 700rhwp uses JE...
Im going to post some ugly pics now.............This piston failed because of valve train problems....not problems with the piston..
http://forums.pelicanparts.com/uploa...1061345981.jpg
TimT 08-19-2003 07:22 PM
another pic
http://forums.pelicanparts.com/uploa...1061346145.jpg
juan ruiz 08-20-2003 04:40 AM
Tim, I know that you use them is just weird that all the ones I hear all had JE Pistons.
ChrisBennet 08-20-2003 06:13 AM
Maybe it's a stastical thing? If most people use JE pistons, most failed pistons will be JE's or something like that.
-Chris
jluetjen 08-20-2003 01:05 PM
Judging by the posts that I've read on the BBS (and most of the responses on this thread so far), most of the people who do build "full-race" 911 motors use JE's. Chris is right, given that piece of information, I'd be shocked if most of the situations like this DIDN"T involve JE pistons.
But then did anyone else noticed that all of the "grenades" discussed here so far involved a 911 motor??? Maybe they're not fit for racing??? ;)
911pcars 08-20-2003 01:20 PM
"If most people use JE pistons, most failed pistons will be JE's or something like that."
I dunno. Do most amateur race folk use JE's versus Mahle's? What do most pro teams use? JE's, Mahle's or ?? The statistical sample on this thread/forum may be a bit too small to determine.
Sherwood Lee
TimT 08-20-2003 03:55 PM
I could post some pics of Mahles that bought the farm....
I believe in the pics I posted, and in the pics Jeff posted. The pistons failed because of some outside influence, ie insufficient clearance, valve train issues, broken valves etc.
You can also hole a piston if you let it run to leans for extended periods..or burn the top ring lands...all of which suck.
The engine that toasted the piston I showed was 12.5:1 with a monster cam (huge lift) 8200 redline 375 at the wheels.. We know this engine has been over revved (missed shifts, downshifts),
If the JE'd were such a potential problem, I dont think they would be so widely used in the racing circles..
cstreit 08-23-2003 02:53 PM
I keep coming back to this thread, like slowing down for a highway wreck. Sorry to see this mess man! :(
Wayne 962 08-23-2003 11:02 PM
How were the rod bolts on this engine? Was the piston / head (deck height) checked before assembly (documented in the book). All of the checks that are detailed in the book need to be done, especially on close-tolerance engines like these.
I think that most 'custom' engines use JE pistons, which means that these 'experimental' high-output engines would tend to show more failures...
-Wayne
snowman 08-24-2003 02:31 PM
Looking at all the picutres again, I still say COOL, cause, what else are you going to say?
How about the WP end of the rod? Does the rod have an oil hole at the top? The color of the wp looks like it got hot, is the picture showing the color accurately? If so this might indicate an oiling problem at the rod ends. What I am thinking about is a rod failure, leading to the rest.
Did the valve put any holes in the piston?
CamB 08-24-2003 09:01 PM
Holy sheit that is broken. Bummer :(
Here is a head I was shown - matched to Mahle 95mm RSR p&c - victim of an overrev or dropped valve (can't remember). It doesn't just happen to JE. Mind you - this had nothing to do with the piston (which didn't look too flash either).
http://forums.pelicanparts.com/uploads/3-0RSR-head.jpg
snowman 08-24-2003 09:44 PM
Yes I agree, at first look it is most likely a valve train problem, ie dropped valve, valve hit piston, whatever. But just to be sure, what about the rod end? Theres a LOT of force trying to suck the piston off the rod at high revs. If it did the results may look similar.
jeffstev 08-25-2003 07:58 PM
Just like a car wreck, I keep going back into the garage and looking (staring for hours) at the mess. I've discovered a few additional things:
- a few of the oil squirters were incorrect installed in the case. they are recessed about 3/4" and "stuck".
- the rod bearing of the "exploded" piston was quite worn. The others weren't nearly as bad. the rods were Pauters, brand new w/ the ARP rod bolts that come with them. The rod "felt" fine on the crank in terms of play, etc. It felt the same as all the others.
- the color in the pics is correct although I didn't see too much friction wear on the wrist pin.
- all of the pads on the rockers were pitted. indications of an oiling problem.
- a couple of the pistons had "shadows" of where the exhaust valve came extremely close to the piston. Not actually touching but close enough that the exhaust gas created a pocket around the valve head and imprinted a faint carbon outline of the valve. Too much damage on the exploded cylinder to see what was happening there.
- I keep coming back to the chain ramp. The tensioners were installed in REVERSE (Left in the right side and vice versa) - refer to the the pic of the ramp. I'm wondering if this created an oiling problem, etc. The bottom of the oil scavenge pump was almost completely plugged with chain ramp debris which could have caused an oil starvation problem coupled w/ the oil squirter problem and caused the pitted rockers, worn rod bearing, etc...
And yes, those are ARP head studs - and they took a severe beating and didnt breat :)
Jeff
Wayne 962 08-26-2003 03:06 AM
Hmm, I'd have to agree with you - sounds plausible on the oil starvation issue. It's often tough to figure out what went wrong first...
-Wayne
ErVikingo 08-28-2003 05:09 AM
For what its worth, I use Cosworths, no problems (yet!). Your situation sucks, not looking forward to it at all
David 08-30-2003 09:16 AM
Sorry to hear about the motor, what a mess!
I would suggest tearing down the motor and looking for indications of a pending failure on other cylinders. You could dye penetrant check the pistons and mag partical check the rods. This would also allow you to check the as built dimensions.
Is there any undamaged fracture surface on the connecting rod? If so, a metallurgist could try to determine if the small end of the rod failed first.
rcwaldo 08-30-2003 12:50 PM
First let me say that sucks and I feel for ya! Luckily it didnt put you into the wall there at Fontana (not sure where on track you were when it let go)
I am kinda curious to your deck height (before explosion).
Our Cosworth track support guy told me while back about their F1 engines were experiencing about one full mm of rod/piston stretch at full RPM, therefore decreasing deck clearances almost .040"! Yes this is at a much higher RPM. But piston inertia is a function of piston speed and weight, so even though yours was at (only) 8k RPM, piston weight is much higher than the F1 example.
Maybe we all have this amount of stretch, but not the technology (ala F1) to identify this anomaly?
Maybe I tend to 'read into' things too much?
Let us know more as you find more...
Chris
dickster 09-10-2003 12:20 AM
wow, thats bad.
chris,
i believe that is normal at higher rpm. on sportsbikes it is recommended to open 'em up to high rpm now and then (if you dont regularly!) to "stretch" the rods - if you dont you run the risk of breaking rings on the wear ridge (which would be too low).
