Pat S's Avatar
nikasil cyl and getting rings to seat
I haven't started my assembly yet but have a question on the nikasil cylinders. Normally honing cylinders gives a nice clean surface and gives the new rings something to "bite" on so they can wear in properly, right.
Since honing the nikasil cylinders is not reccomended, how do you prep them for breakin? How do you clean them? Or do you just not worry about it and wipe them down with alcohol then lightly coat with oil?
I plan to use Goetz rings from Pelican if it makes any difference.
Pat
Old 08-23-2003, 02:49 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I belive you use a ball hone on them. It doesn't cut up the nikasil like a regular hone and it cleans them up nice. I'm just a novice with all his info from books so hopefully someone will confirm this.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 08-23-2003, 09:03 PM
Pat S's Avatar
So should they be honed then? Or only sometimes? If they aren't honed and are just cleaned will the Goetz rings still seat in correct?
If it helps the engine had good leakdown and is being rebuilt due to pulled studs.
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 08-24-2003, 08:16 AM
Senior Member
Doug Zielke's Avatar
A very good question. Hopefully John Walker or Steve Weiner will chime in on this one.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 08-24-2003, 08:50 AM
If the cylinders are glazed, they should be lightly honed so that the rings will seat.
The only way you can do this is with diamond hones, and we do this using a torque plate (to simulate the heads being bolted up) and with the cylinders bolted up into a case half. The keeps the bores round when they are at operating temperatures.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-24-2003, 06:09 PM
Pat S's Avatar
Thanks Steve.
Not sure I'd know what glaze looks like though... How does this look? It were just cleaned with brake cleaner and cloth. I still have a bit of carbon to get off at the edge there but didn't want to scrub too hard.
http://mywebpages.comcast.net/patrick.snyder/cyl.jpg
http://mywebpages.comcast.net/patrick.snyder/cyl2.jpg
Pat
Old 08-24-2003, 06:56 PM
Senior Member
I don't know if this image will help you, but the *new* Mahle Nikasil's I used in my rebuild looked like this:
Old 08-24-2003, 07:31 PM
Banned
snowman's Avatar
The silicone grape type ball hone is the one to use. It will NOT hurt your cylinders, and will insure a good cross hatch pattern for good oiling. This type of hone does NOT remove any material ( less than 0,0001") but puts the correct cross hatch pattern in place to insure proper seating of the rings.
Old 08-24-2003, 10:09 PM
Hi Pat:
Good job on cleaning things up!
I was unable to see the original crosshatch honing pattern in your pics since they were not quite sharp enough,....
As long as your cylinders' original crosshatch patterns can be clearly seen within the piston's travel, you will be fine. These rarely need honing. You can observe the Mahle factory finish by observing the cylinder below the BDC position. Its obvious to see where the pistons stop,.........
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-24-2003, 11:13 PM
What can be done with the Alusil cylinders? Can you re-ring those and get them to seat the same way?
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 08-28-2003, 08:00 PM
Senior Member
Superman did, and his car runs strong as any. I know....I drove it!
Old 08-28-2003, 09:01 PM
Hi:
Alusil cylinders cannot be honed at all. If they are scored or glazed, one simply replaces them.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-29-2003, 12:52 AM
Author of "101 Projects"
Wayne 962's Avatar
Steve's right - As I wrote in the book, Alusil can be re-ringed with mixed and unpredictable results. Sometimes they work, sometimes they don't - it's a gamble. Any good, professional shop typically won't install re-ringed Alusils and give a warranty at all. The best way is to get a set of new or re-plated Nikasil cylinders.
Note - you cannot mix and match Nikasil and Alusil *pistons* either. The rule of thumb is that the Nikasil is a hard cylinder wall and a soft piston. The Alusil pistons are harder and are used with the softer Alusil cylinders.
One important caveat - I do believe that you can effectively take an Alusil cylinder and have it replated with Nikasil (basically using the Alusils as cores). I'm 98% sure this is possible (off the top of my head).
-Wayne
Old 08-29-2003, 04:05 AM
Pat S's Avatar
Just to update all, I've decided to do the right thing with my Nikasils and have shipped my pistons/cylinders off to EBS Racing for a good inspection. Hopefully I can get away with reusing them.
Pat
Old 08-29-2003, 05:26 AM
A slight correction. During manufacture, Alusil cylinders are etched to reveal silicon as the main wearing surface, thus this surface is very hard. Alusil pistons are aluminum, usually cast and relatively soft. To avoid excessive wear, Alusil pistons are iron-coated to provide a buffer against the silicon. As Wayne suggests, Nikasil and Alusil pistons and cylinders are not interchangeable.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 08-29-2003, 02:07 PM
