 Air injector plugs for 68 2.0L heads The air injector holes in my heads are 12mm with what appears to be a 1.25mm pitch. Has anyone else looked for plugs this size? Has anyone found plugs this size? Thanks Joe |
 "off the shelf" plugs seem to be 1.5 pitch but perhaps you could make plugs from 12 x 1.25 full threaded socket head cap screws or 12 x1.25 set screws if sealing on the threads is sufficient.  See the on-line catalog at this website: http://www.metricmcc.com/ |
 Thanks for the site!  I was having a lot of trouble finding a M12x1.25 in a socket head. Joe |
 So I ordered some M12x1.25 socket head cap screws only to find I did not measure the thread pitch correctly.  The air injectors are even finer thread, probably M12x1.0.  I have been able to find taps with this thread, so I guess I will search for a die and make some plugs.  :( |
 air injector plugs are usually 10mm dia with 1mm pitch. |
 ...and it's nice if they are tapered as well.  I tried using a straight thread and blew a plug out in 500 miles.  That was sealed with red loctite, too! I got my tapered plugs from jhelgesen on this board. It might be worth PMing him with specs to see if he has what you need. |
| All times are GMT -8. The time now is 12:52 PM. |
