-   -   Engine Rebuild Book Question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/124426-engine-rebuild-book-question.html)
tgarnoldo 08-22-2003 08:38 AM
Wanye,
you included the dimensions to make the rod and chain holders used in the case assembly. I just can find the width of the parts anywhere? What is this dimension?
Thanks,
Arnie
dtw 08-22-2003 10:16 AM
Width is not a critical dimension. Just measure the width of your rods and timing chains and approximate that with your holding tools...
William Miller 08-22-2003 01:47 PM
I made mine with a piece of the tin c-clamp that holds the joints of heating duct together. It's about 1" wide. I couldn't bend it to exactly the shape of the pictures but it worked great. Once the case was together I took my tin snips and cut them up. In the can they went.
I used this because it was there. I'm sure you can get it at any home center for a few bucks. I think I used about 4-6 feet. (At the most.)
Wayne 962 08-23-2003 01:06 PM
Hmm, cardboard would probably work pretty well...
-Wayne
cstreit 08-23-2003 02:51 PM
Made mine out of some hardware store aluminum... like 3/4" width, bent by hand... Easy-peezy
http://forums.pelicanparts.com/uploa...1061675491.jpg
http://forums.pelicanparts.com/uploa...1061675501.jpg
Wayne 962 08-23-2003 11:03 PM
String to the ceiling is one idea, but then you can't easily attach the other case half...
-Wayne
