Question Cylinder Height
I am rebuilding my 2.7 and 2 of my cylinder on the same bank were damaged. The original cylinders are a 5 in height and I have a chance to buy 3 new cylinders the are 6's. Is it okay to have a bank of 5's and the other 6's?
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 09-11-2003, 09:19 PM
Yes, it's okay. You just need each bank to have the same height cylinders.
-Rob
1980sc
Old 09-12-2003, 07:24 AM
Super Moderator
cstreit's Avatar
You would also need the base gaskets to make up for the difference if the height between Left and Right weas significant. Otherwise you would have different deck heights and therefore compression ratios from L to R.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-12-2003, 07:45 AM
Does anyone know what the difference in deck height is between a number 5 and 6 cylinder? Would I have to bring up the bank of number 5 cylinders to the same height of the 6’s, because of a compression differential?
PorschePilot
MID9 Member
Old 09-12-2003, 09:38 AM
