PJMARKOW's Avatar
Boring Nikasil Cylinders
Is it possible to bore porsche nikasil cylinders. Say 95mm 3 litre ones out to 98mm, and then have them replated?
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 08-29-2003, 01:17 AM
Author of "101 Projects"
Wayne 962's Avatar
Yes, I'm pretty sure this is possible. I think anything larger than 98mm gets dicey though.
-Wayne
P.S I have a set of 95mm ones on eBay: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&category=33617&item=2429702431
Old 08-29-2003, 03:56 AM
PJMARKOW's Avatar
Thanks Wayne. I wasn't sure how much meat her is in a 95mm cylinder bore. There is a company here in Australia offering a boring and replating service, using a ceramic/silicon compound which they say is harder than nikasil. They do racing motorbike engines, car engines etc. I have contacted them recgarding there service and whether they have ever done any porsche work? I'll keep you posted.
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 08-29-2003, 10:18 PM
Warren Hall Student
Bobboloo's Avatar
It sounds like the surface would be similar to Nikasil but you should check with them on the material that the rings should be made of. Different cylinders sometimes require different ring material for proper break in.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 08-30-2003, 10:45 AM
I would be interested in the company...can you name them or pm me? Thanks
Mark....
Old 08-31-2003, 10:16 PM
But not in Australia!
Old 08-31-2003, 10:32 PM
PJMARKOW's Avatar
The company is Electrosil (www.Electrosil.com.au), and they do bore and replate Porsche cylinders. They're in Briar Hill Melbourne (Australia). If you want a rebore they would require the oversized pistons to do a proper job. The cost is $350AU for replating and $55AU for reboring, so by the time you add oversized pistons, rings and pins, it may just be cheaper to get them from the US. Do you know of anyone in Australia that makes custome forged pistons.
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 09-01-2003, 01:38 AM
