How to loose the fan nut (direction)
Can someone tell me how you remove the fan nut, to loose it must you turn the nut clockwise or anti clockwise.
Thankx, Peter (novice porsche driver 911SC) |
Righty tighty, lefty loosey
Counter (anti) clockwise; Make sure you use the right tool to hold the fan while loosening it. |
IMHO, I'm not a pro, The best tool I found for holding the shaft while turning the nut (turn nut counter clockwise) is the factory tool from the toolkit. It is L shaped with the exact fit and size.
| All times are GMT -8. The time now is 09:09 AM. |
