-   -   3.4 L piston upgrade help (http://forums.pelicanparts.com/911-engine-rebuilding-forum/129184-3-4-l-piston-upgrade-help.html)
wingmanjim 09-26-2003 03:55 PM
need help I purchase a set of 3.4 l piston and on the bill of sale it state that . angle and chamfering modification to heads is needed.but when place on heads seems to be a perfect fit ,am i missing something please help
911pcars 09-26-2003 04:51 PM
With modeling clay or soft solder on piston crown, check piston-to-head clearance and piston-to-valve clearances, then adjust accordingly. Use cylinder 1 with head, cam and a couple of rockers installed, then tell your Porsche machine shop what you have. While you're at it, determine true TDC and mark your pulley before beginning.
Sherwood Lee
http://members.rennlist.org/911pcars
