-   -   Broke an Oil Ring Installing (http://forums.pelicanparts.com/911-engine-rebuilding-forum/129209-broke-oil-ring-installing.html)
tgarnoldo 09-26-2003 08:08 PM
I broke an oil ring installing it on the piston. Is there any where I could get a single piston set of rings. I have the old rings and could use them in a pinch. Any thoughts? BTW It is for a 3.2l Carrera motor.
Thanks,
Arnie
AFJuvat 09-29-2003 05:08 AM
Who did you buy the rings from?
Most places I know will not break up a set of rings to sell one.
AFJuvat
tgarnoldo 09-29-2003 06:09 AM
Danke
Thanks for your reply, I found the same issue. I spoke with my machinist and was told that intalling one old oil ring wouldn't be a problem, so I picked my best one and moved on...
Thanks,
Arnie
AFJuvat... I agree fully with your closing...
Wayne 962 10-05-2003 09:57 AM
Yikes, your machinist was kidding right? Cutting corners like this on a 911 engine rebuild? I don't think any of the machine shops I know of would recommend using an old, used part in a $8K rebuild - it's just not worth it, and it's just not done.
I think we can get you a single set of rings if you need them...
-Wayne
David 10-07-2003 06:28 AM
I had this same problem a few weeks ago and was able to buy one set of rings from ProTechnik in Houston.
Wayne, I would imagine this happens often enough to warrant selling individual sets of rings.
smestas 05-10-2004 01:09 PM
Same thing just happened to me here!
I called and the customer service guy at Pelican Parts and they said they don’t break up sets. :(
Does anyone else know where I might be able to get 1 set of GOETZE rings (95mm-1.5 X 1.75 X 4.0mm), for a '78SC?
john walker's workshop 05-10-2004 01:27 PM
Wayne 962 05-10-2004 01:27 PM
Yes, we can sell individual rings, give Tom a call at 1-888-280-7799x221 and he can special order these for you. I'm having Eugene add these to the catalog too...
-Wayne
