-   -   Really stupid question. left vs right cam (http://forums.pelicanparts.com/911-engine-rebuilding-forum/130520-really-stupid-question-left-vs-right-cam.html)
Pat S 10-07-2003 05:31 AM
Okay,
I'll surely win the dumb question of the day award with this :)
In the rebuild book figure 6-5 clearly shows the left cam as having lobes that form a very wide V, while the right has a close V lob config.
However, which is the left and right side of the engine. My guess is that left/right is from the rear of the engine, there fore left is 1-2-3 and right is 4-5-6. But I want to make sure it isn't left right from the front (flywheel) side of the engine.
Thanks,
Pat
ChrisBennet 10-07-2003 05:41 AM
Yes, the 123 side is the left side.
-Chris
Tim Walsh 10-07-2003 05:42 AM
from the BA book: The wide lobed cams make a V or an L for left and the narrow lobed cam looks like rabbit ears, R for right.
Wayne 962 10-08-2003 01:02 AM
The intro to the Rebuild book goes over the nomenclature of what is considered left/right and front/back. Take a look at page 6...
-Wayne
Mark McClure 10-08-2003 05:49 PM
Just to follow on from what was titled a silly question.........what would happen if the cams were put in on the wrong sides? Valve to piston contact?
Tim Walsh 10-08-2003 06:16 PM
I belive it would try and run backwards.
Wayne 962 10-09-2003 09:21 PM
Technically yes, the engine would try to run backwards, which would tie up the chains, and would be impossible anyways, considering the distributor would be miswired...
-Wayne
Mark McClure 10-10-2003 12:08 AM
OK........silly question answered!
