Usable Dinged Heads
I just got my heads back from the machine shop and it looks like one of them had some previous damage. It looks like the damaged head had a failed valve or guide and suffered some dings to the top of the head. As the car was running fine before I tore it down (broken head stud different cylinder) should I be concerned with the dings? Should I try to knock 'em down a bit? I've read that any obtrusions in the cylinder can get over heated and cause damage.
Any advice would be appreciated. Damge shot 1 ![]() Damage shot 2 ![]() Beauty shot ![]() Before bead blasting
those dings won't cause any problems, as they're fairly blunt, but smooth them a bit anyways. also, pull out the sparkplug(s), as they harbor glass bead. better now than when the heads are installed. and chase all the sparkplug threads.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 10-09-2003 at 03:15 PM.. |
Author of "101 Projects"
Your machine shop should have pulled out the plugs before blasting?
The dings don't make too much of a difference - I wouldn't worry about it, but it can't hurt to smooth them out like JW says... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
![]() John and Wayne thanks for the replies! I'm going to sleep much better tonight knowing that I dont have to buy a new head. What do you guys recomend to use for knocking the high spots down a bit? Im thinking a dremel tool. Last edited by smestas; 10-09-2003 at 11:01 PM.. |
So you just had the heads blasted and nothing else? When blasting heads, they should 100% be disassembled (no valves, etc.)...
-Wayne
