-   -   Torque Questions (http://forums.pelicanparts.com/911-engine-rebuilding-forum/130975-torque-questions.html)
dporsche74 10-09-2003 10:36 PM
Torque Questions
Hello ,
I have a few question on what certin bolts/nuts are torqued to, I have a few manuals and none say what these bolt/nuts are torqued to? Pretty soft just to tighten them up , the engine is 69 911E 2.0
10 - 13mm nylon nuts timing chain housing to block.
4 - 15mm chain rails bolts into the block
6 - 10mm bolts behind the cams spocket holding the aluminium plate and seals.
thanks
Dave
Wayne 962 10-09-2003 11:42 PM
Get one of the Engine Rebuild Books: http://www.101projects.com - Appendix A has torque tables for all the nuts used on the 911 engine...
-Wayne
dporsche74 10-10-2003 08:26 AM
sigh.... Does anyone have this book??? If so could you look in it a give me the numbers I need
thanks
Wayne 962 10-10-2003 03:07 PM
I spent thousands of hours compiling statistics and creating the book.
See here:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/95338-read-me-first-information-regarding-engine-rebuild-book-forum.html
-Wayne
