Weber 40 IDA set-ups
I'm looking for recommendations on my Weber set-up. My new engine is a 2.8, J&E pistons 9.5:1, early S-cams, 35mm intake and 36mm exhaust ports, SSI and dual-out exhaust, single ignition and RS distributor. Also, I'm at sea level, and the car is mostly used on the track. This is what I think I need:
Venturies: 36mm Main Jets: 160 Idle Jets: 60 Air Correction Jets: 180 Emulsion Tubes: F3 Is this reasonable? Also, where should I get these parts? Thanks, JP |
A lot of Webber Parts are available through PMO and Eurometrix.
that setup should get you started ok.
Right - looks like a good starter. The expert is Richard Parr at PMO (also Steve Weiner is good at these setups, I hear from his customers)...
-Wayne |
| All times are GMT -8. The time now is 11:16 AM. |
