-   -   idle arm question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/132163-idle-arm-question.html)
80sc man 10-19-2003 10:07 AM
idle arm question
I just installed the chain tensioners and have a question. I have the later style idle arm alreay as it is an 82. There is about 3/16 of an inch play in the arm as it can slide back and forth on the shaft. Is this nomal????
Wayne 962 10-19-2003 11:10 AM
Yup, that's normal. It should not be a tight fit...
-Wayne
80sc man 10-19-2003 12:08 PM
Alrighty, Thanks!!
