Piston Squirter Cleaning - 4/5/6
I've read several posts on cleaning the piston squirters but I am still totally lost.
Where do you plug the gallery? I've plugged both ends on all through bolts, do I need to plug the port beside the oil thermostat and the two ports perpendicular to that? Like I said I'm lost, (and Waynes book is very sketchy in this area). :( Any one got a better description that even an utter moron could comprehend? |
Take a look here:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/128269-aaarg-stupid-piston-squirters.html I basically took an old fuel line, wrapped it in electrical tape to make a real good seal, Plugged up the through bolt hole, then shot cleaner from the bearing journals holes under high pressure. Pat |
Maybe I'm not sealing far enough into the bolt hole? That would leave me connected to the gallery, which I should be blocking off with a longer plug?
I pushed my 'plug' in much further, ie far enough to block off the gallery. Now I can blow air through the squirter.
| All times are GMT -8. The time now is 09:59 PM. |
