-   -   Best book (http://forums.pelicanparts.com/911-engine-rebuilding-forum/133891-best-book.html)
fightini 10-31-2003 09:53 AM
Best book
wayne salute to you guys ,just wanted
you to know i got both books ,and they
were both great.
one thing i would like to know on cam timing ,once you set cam timing #1 cyl.
then do you adjust valve for #1 before
you check clearence for the overlap as you turn engine to #4 ,newbie.
vern
Wayne 962 10-31-2003 08:39 PM
Thanks for the feedback. Once you install each rocker, you should immediately adjust the clearances. The clearances must be adjusted prior to setting the cam timing...
-Wayne
