-   -   Camshaft change (http://forums.pelicanparts.com/911-engine-rebuilding-forum/133936-camshaft-change.html)
CHP 10-31-2003 06:52 PM
Camshaft change
Does installing 964 camshafts in an '87 3.2 litre make a noticable difference and are there any downsides?
Doug Zielke 10-31-2003 07:04 PM
Careful what you do....your car may no longer pass 'AirCare' (or as the 'Bomber calls it: 'AirScare').
aigel 10-31-2003 07:36 PM
I thought the 964 was a good (not too radical) and affordable (since non custom) cam for the 3.0 CIS engines. I'd think unless you are in there already, stay with the stock cams. If you do mods, get a custom cam grind for the 3.2 and whatever modifications you are planning.
George
