nreed's Avatar
Engine/Tranny separation
First...a big thank you to Wayne. You encouraged me through your books to start my rebuild project. Fantastic web site.
Now that I have the engine and transmission out on the floor I am having trouble separating the two. Is it because I did not remove the clutch helper spring assembly? (I tried to do that last night but I needed a circlip removal tool from work). If not, what is the trick besides removing the 4 nuts that hold the two together ?
Regards to all,
Norm
86 930
93 Volvo 945T
Old 11-13-2003, 05:23 AM
Friend of Warren
Norm, once you get the helper spring removed and the 4 bolts removed (which should include the starter) the tranny just slides off.
Kurt V
Old 11-13-2003, 06:17 AM
nreed's Avatar
Thanks for your kind patient response...I was sure it was the helper spring...I guess it puts enough pressure on the clutch so it won't allow separation.
I have now learned to follow instructions explicitly.
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 11-13-2003, 06:27 AM
Friend of Warren
You wouldn't be the first person, including me, to learn this the hard way.
Kurt V
Old 11-13-2003, 06:33 AM
the short lower lever, held on by a snap ring needs to come off first, then it will slide off, unless the shaft is rusted to the freewheeling long arm with the horseshoe spring, in which case you will have to remove it with heat, air hammer, or whatever.
206 637 4071
Old 11-13-2003, 08:15 AM
nreed, give me a shout if you need a hand - just went thru the same things a few weeks ago. And look at the factory service manual - it does have a detailed section on removing engine & separate tranny from it.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 11-13-2003, 09:55 AM
nreed's Avatar
thanks Patrick...
Norm '86 930
Old 11-13-2003, 10:00 AM
Author of "101 Projects"
Wayne 962's Avatar
I had to learn how to do this *before* I wrote the instructions...
Been there too!
-Wayne
Old 11-13-2003, 02:00 PM
