Hello,
I am currently looking for a 3.0 engine for my project car. This past weekend I went to look at one (an '82 3.0 with a reported/documented 77K miles, Carerra tensioners, turbo valve covers) and did a compression test on it. The seller said engine has been sitting for approximately 1 year (out of car). The results of the test are as follows: #1 175 #2 165 #3 40-50 (highest after 3 tests) #4 145 #5 158 #6 135 Seems like left bank higher and better but with #3 very bad, as opposed to right side lower but within 15% of each other. Tested #3 3 times, after first time shot small amt of oil into cylinder and results did not improve. I do own and have read Wayne's book and section on copression/leakdown but it does not completely answer my questions on reading this type of result. I have an idea of what the very low #3 may mean, and can anyone explain why the drastic difference between left and right hemispheres/banks? Can these results be accurate or at least some indicator of engine health without starting and running engine prior to test (which might be difficult to have done in this case)? I would appreciate any views on what people think of the general condition of this engine. Does it look like a rebuild here and to what extent? Thanks
Ed _________________________ '95 993 Cabriolet '83 911 SC Coupe (gone but not forgotten) '84 944 Coupe (willed to brother) |
Now in 993 land ...
Ed:
#3 is bad news. Keep looking, unless you want to rebuild it and it is a cheap core. Of couse, after sitting, there may be carbon stuck under the valve, or some other lucky deal, but it won't run right with that compression and you would have to dig into the engine to know what's up. Why does the engine not reside in a vehicle? Usually there is a good reason... George |
Author of "101 Projects"
Right - no real way to tell on an engine that has been sitting for so long. Sometimes they have 100% leakage, only to fire right up and cure themselves when running. Sometimes...
Unfortunately, there are no definite answers... Side to side differences can be caused by misadjusted carbs (if it has carbs on it), or other clogs in the fuel injection system. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
The engine is from a front-end collision '82 Targa. Owner bought it as spare parts car for his '83 SC restoration. Used some parts, parted out rest, and this engine remains. Owner also stated he never ran the engine due to the fuel tank being heavily damaged and was afraid of causing fire with jumper pack.
Engine is complete original with fuel injection. Would clogs in fuel injection cause compression result variations like this if engine has not been run? Would it be wise to try a retest with fuel injection system off of engine? Is the only way to get accurate comp test results to try to "bench run" the engine first?
Friend of Warren
Ed the fuel injection system isn't going to affect the compression readings. I have to agree with the others, I would only buy this engine as a core fully expecting to do a full rebuild. If I wanted a running engine, I would be looking elsewhere.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks. Seems like that is the general consensus. What is it worth as a core (engine is complete).....around $1800?
Also, since I am still looking, anyone with any leads on a later 3.0 feel free to chime in.
get it cheap while you can. there aren't that many around. it may be fine, being that it's been sitting, and carbon may have fallen between valve and seat on that cylinder. it may need a valve grind, but we can walk you thru that.
Slumlord
At $1,800 I would buy it right away.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Well, he wanted $4700 for the complete engine, tranny still attached. I have not made him an offer, but I am asking what everyone thinks it is worth (the $1800).
considering that a valve grind done at a shop could go $3000, the price should reflect the repair costs. that leaves $1700. less than $2k, without the trans would be good for a rebuildable core.
Slumlord
On the ther hand, how many rebuildable cores have you seen lately for under $2K? Around $3,500 is lowest I've seen.
But $3K, is that a a typo John? -Wayne
that would be take the engine out, teardown, go thru the heads, reassemble and install. new valves, guides, springs, filters, tuneup parts, etc. 30 hours labor plus parts. heads only $1000ish. rings, rod brgs, chains, sprockets, etc, would be extra.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 11-13-2003 at 03:15 PM.. |
I think $3500 for a core is a bit high. $2K ish is more in line.
So it seems that you guys are saying pay around $2K for the engine and assume around $3K in addional rebuild costs? John, what do you mean by "teardown, go through the heads?" Does the 3K include you taking engine out and reinstalling?....I'm not seeing the whole picture. What would it cost for an "I ship you engine, you rebuild and ship back fixened" scenario?
Ed _________________________ '95 993 Cabriolet '83 911 SC Coupe (gone but not forgotten) '84 944 Coupe (willed to brother) Last edited by 911gilley; 11-13-2003 at 05:19 PM.. |
-Wayne
That's what I thought. I guess John was generalizing when he said for $3K he would "teardown, go thru heads..." I now assume that he means if he finds anything wrong during the teardown other than what he stated he would replace in that scenario, it will be additional $.
they're all a "pig in a poke" until you have it spread out in front of you.
yes, the $3K includes taking it out of the car and reinstalling. and that's limited to just doing the valve grind. it's time consuming, and time is money as you know. you could do it yourself, and just farm the heads out for much less. get wayne's book.
