Slumlord
Porsche_monkey's Avatar
Loctiting Cylinder Studs
Am I the only one that thinks it's a bad idea to loctite the cylinder studs without tension?
It seems to me they should be at least slightly loaded to force the threads into their final engagement position prior to letting the loctite cure.
I was planning to slide a pipe over the studs and pre-load with a nut overnight while the loctite cures. Am I going overboard?
Old 11-13-2003, 08:52 AM
ValveFloat's Avatar
My "engine rebuild mentor" (MT912RS) thought this also, and I agreed, so I waited to put the studs in until I was ready to install the heads. I had to be carefull to get the cylinders aligned without the studs in place, but it worked out fine.
Joe
1993 C2
Old 11-13-2003, 09:20 AM
Slumlord
How about the engagement of the two threads relative to one another? There is always clearance between the stud and thread, witness the wiggle in an inserted stud, therefore the gaps between mating threads will depend on the tension. A bigger gap will cure and harden with loctite, but you could conceivably break the joint later on, either at assembly or when running the engine hot.
I would like to see the loctite cure with the thread faces loaded against each other.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 11-13-2003, 02:15 PM
Navin Johnson
TimT's Avatar
The engagement of the threads should be pretty snug, If you have "wiggle" something doesnt sound right.Most threads on the stud should be in intimate contact with the threads of the case (casesaver, timesert, etc) any loctite you apply will be displaced to any voids, then cure. Axial play should be nil.
I wont hurt anything to install the studs the way you describe, dont think it has any real benefits though..
'69 911 GT-5
'75 914 GT-3
and others
Old 11-13-2003, 06:46 PM
Slumlord
head studs and new timeserts
Check out this thread, it's what started me thinking.
Old 11-14-2003, 06:03 AM
Author of "101 Projects"
Wayne 962's Avatar
It's normal to have some wiggling, particularly if you are using case savers. There are many ways to do things, but to me, this appears to be a non-issue. The Loctite 271 will be enough to keep the studs secure and to keep them from turning when you tighten the head studs...
-Wayne
Old 11-15-2003, 03:48 AM
