P/C removal for stud removal ??
Well my case will be sent to a local M.S. to get the remaining 6 studs out,..Is it necessary to remove the P/C's due to the heat that will be created or just better access ???...thanks Frank
yes.
I thoght so....Thanks
If they are Alusil, don't pull the pistons out of the cylinders...
-Wayne |
Yes, just throw them away whole !
Well Iam thinking of having them re-plated to nikisil...Frank
I had good luck w EBS in NV re-plating my nikisils.
| All times are GMT -8. The time now is 10:19 PM. |
