P234 flywheel seal tool
Is the P234 tool the correct one for the flywheel seal on a 1995 993 motor - mine looks like it is too small diamter wise to work.
i'll have to check my rubber hammer for that number.
Tool installation seal = not super useful...
-Wayne |
Ok, I get it - I'll stick to using a rubber hammer or the end of a rachet:)!
It would be better to invest in the flywheel seal removal tool, as this is usually where the problems arise.
-Wayne |
Part# 0000.000 = sheet metal screw and a pair of pliers....
A pair of vise grips with a slide hammer welded/rigged to end.
Picture courtesy of 5axis: http://forums.pelicanparts.com/uploa...1068816477.jpg |
John,
What is that thing (what application is it originally intended for)? Or did you make it? Looks like it would work by prying against the crank end? I like it. It would eliminate drilling (metal shavings) into old seal metal and scoring/damaging sealing surface! |
That's what I used - $9.00 at Sears.
Thanks. Awesome. I'll have to pick one up.
| All times are GMT -8. The time now is 04:52 PM. |
