-   -   Compression Ratio... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/137228-compression-ratio.html)
schubee 11-25-2003 03:42 PM
This may be a stupid question:
Is it possible to acheive a 11.3:1 compression ratio with stock p&c's for a 3.6 964 engine? Or would I have to use JE or another brand p&c's to achieve such a ratio?
Steve@Rennsport 11-25-2003 11:24 PM
Hi John:
To get a real 11.3:1 CR, you will need either a Mahle 3.8 RSR P/C set or a set of JE's in your 100mm cylinders.
If its a street motor, I'd use the Mahle's for longevity.
