1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Quick info out of rebuild book
I don't have it in front of me but i'm in the process of buying a machinist ruler. Does anyone have the value that must be measured when aligning the cam gears for proper shimming?
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 12-04-2003, 10:47 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
There is really no exact 'value' to be measured, but rather a comparison. You need to take your initial measurement from the end of the intermediate shaft flange to its timing gear, then compare that measurement to the right side cam sprocket measurement.....this is where you'll need a good straight edge. For the left side measurement, you subtract 54.80mm.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 12-04-2003, 10:59 AM
1fastredsc's Avatar
That's all i needed to know, i was purchasing a machinist ruler since they aren't expensive. My dad picked up a snap on straight edge off of ebay. I ended up buying two, one in 150mm semi flexible, and the other in 300mm non flex. Not bad for 20$.
2007 Mazda 3 hatch
Old 12-04-2003, 11:04 AM
