-   -   Tach not working II (http://forums.pelicanparts.com/911-engine-rebuilding-forum/137972-tach-not-working-ii.html)
tfranko29 12-02-2003 04:58 AM
Tach not working II
After I've located the black/purple wire running from the distributor, to the multi-pin connector, does the black/purple wire then run directly to the transitorized tach, or does an electric sender/unit exist that could be burned out? (1972 911T with 1967 911 engine, Perma Tune and Bosch Blue coil)
Thanks for helping.
