After I've located the black/purple wire running from the distributor, to the multi-pin connector, does the black/purple wire then run directly to the transitorized tach, or does an electric sender/unit exist that could be burned out? (1972 911T with 1967 911 engine, Perma Tune and Bosch Blue coil)
Thanks for helping.
Frank in Naples, FL 1972 911T 1983 944 |
