Question chain tensioner wear
While getting ready to install new tensioners I noticed there is a lot of wear on the chain housing. the chains seem to be centered on the rails and on all of the sprockets. Could it be rails were not installed correctly or maybe the engine has been repaired already ?
1983 sc 3.0 engine # 64D5446
Bruno Krygier
Old 12-03-2003, 05:17 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
a most interesting situation. I would measure the sprocket depth and see how off if it is (should be less than 0.25mm). With wear like that on your chain tensioner and your housing I would really wonder. The chain ramps guide the chain but they don't set how deep the chain is in the housing.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-03-2003, 05:46 AM
Senior Member
Doug Zielke's Avatar
There seems to be a lot of sludge on that idler sprocket....wonder what the inside of the motor looks like??
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 12-03-2003, 08:15 AM
Wayne,
It dosn't hit the hhousing , When I turn the motor by hand the chains run straight they are lined up and run right on the center of the chain rails. I am wondering if the tensioner was replaced years ago and that is what did the damage? I would hate to put everything back together not knowing for sure
bk
Old 12-03-2003, 02:24 PM
I would say it's old dammage, but the wear marks look pretty clean.
This could happen if the sprkets were way out of alignment or a very worn chain and tensioner slopping arround in the case.
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 12-05-2003, 11:25 AM
Now in 993 land ...
aigel's Avatar
My vote goes towards old damage. However, you want to make sure all those shavings that were created aren't in your engine any more!
G
81 SC (sold)
Old 12-05-2003, 11:33 PM
Author of "101 Projects"
Wayne 962's Avatar
You said:
"I noticed there is a lot of wear on the chain housing"
and:
"It dosn't hit the housing..."
Two statements that contradict each other?
I guess I don't understand the question or the situation.
My original question could be reworded as "where is the damage to the housing?"
-Wayne
Old 12-07-2003, 01:51 PM
Sorry for not being more clear. the wear on the housing is behind the numbers #1 #2 and #3 in the photo. The chain at one time must have been loose and wore into the housing. As much as i can tell now the chain is rides straigt on the chain rails. so I was thinking this was prior damage and maybe had the tensiners put in at one time. I hope this is more clear
thanks
bruno
Old 12-07-2003, 02:43 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
I think this might help. Look at wear inside the green circles.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 12-09-2003, 02:00 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
The rails snap into place and are thererfore hard to install wrong.
This could be a cam sprocket not parallel to the intermediate shaft, but that would be a noticeable noise as soon as the motor was started (after a rebuild or cam work) and then shut down to investigate. A situation like this should never arise because some binding/resistance and noise would occur when turning over the motor by hand as you were doing the repair work.
Those spots in the green circles are where the chain bounces off the chain housing and ramp when a tensioner goes down. Otherwise known as the "chain dragged out of a metal garbage can" sound.
If your car isn't making that sound now, i'd have to think that picture is previous damage. Not something happening now.
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 12-09-2003, 10:28 AM
Thank you Keven and everyone else with input. This is what I am thinking also prior damage
bk
Old 12-09-2003, 04:32 PM
No Expert
jgparker's Avatar
Since the inside of the chain housing is brown from oil stains, and the damage is clean, I would have to conclude the contact might be fresh. Also, the wear on the idler scares me too. Is the inside of the chain worn too? I would check the sprocket alignment very, very carefully before I would blow this symptom off. Every odd behavior is a clue... Don't miss an important one.
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 12-09-2003, 06:59 PM
here is an update on the chain housing wear. It is the left side camshaft sprocket that was installed the same as the right side instead of being reversed with the cup side out
bk
Old 12-15-2003, 03:39 PM
No Expert
jgparker's Avatar
Good catch BK. In hindsight, I can see that the pulley is backwards in the picture. Looks like your tensioner update is going to turn into a bigger job. (Re-aligning the sprocket, and retiming the cam). You might consider replacing the chain while your at it too... real big job.
Good luck,
JP
Old 12-15-2003, 04:12 PM
KTL KTL is offline
Schleprock
KTL's Avatar
My apologies for a bad diagnosis. That wear on the housing is obviously due to what you pointed out as being the left cam gear installed backwards.
Like I said previously, that sound would be very noisy as soon as the motor was started after the work was done. Someone should have shut it down right away and investigated. The sound should have been present turning over the motor while timing cams and setting valve clearances!!!!!!
When the chain doesn't ride parallel, it wears the gear sides fast. Just like jgparker pointed out on the idler gear. This same wear is going to be on the intermediate shaft gears for that side. To fix it right, those int. gears, along with the idler gears should be addressed as well. Worn gears will wear a new chain in short time.
Kevin L
Past: '87 Carrera
Old 12-15-2003, 07:50 PM
Can you see in the hole to see if the idler sprokets were installed right?
I can't remember exactly but I think they could be put on backwards too.
Great catch! Now you got me wondering. Do you know where your sprokets are?
Kevin, when I installed my chain ramps I noticed that they can in fact be pushed in too far. Mine didn't exactly "snap" but I could feel it like a detent. I put the first one inn too far and had to pull it back out to the right spot.
BK, where are you goint to go from here? It looked like you saved yorself from a future catastrophe, but I doub't you thought this projects would take you this deep.
Bill Miller
81 Targa Guards Red
Old 12-16-2003, 08:58 AM
