"S" cams in 4-bearing?
Are new early S cams (pre-73) available in 4-bearing from Porsche? If so, what are the part numbers?
I'd also like to know the part numbers for original 3-bearing ones.
TIA
Old 12-03-2003, 09:20 AM
call webcam and have them do up some 4 bearing with S grind for you. or if you already have early S cams, use 3 bearing cam towers on whatever engine you build.
206 637 4071
Old 12-03-2003, 01:20 PM
Author of "101 Projects"
Wayne 962's Avatar
The part numbers should be in the Engine Rebuild book's appendix.
It's almost easier to run the 3-bearing cam towers instead of the 4-bearing ones - there is no real known cause of failure for the 3-bearing ones...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 (October 2018)
Check out our new site: Dempsey Motorsports
Old 12-03-2003, 01:54 PM
