Sticky question.... i have a 3.0L and $4K. What to do?
Hi guys, a dream situation. I received 4K that wasnt planned.... so i MUST spend it right? on a Porsche related way, right? so....
I have a 1978SC 3.0L, leak-free, strong pullling good but not documented. I dont know if it has been rebuild or not. What should i do? 1) Upgrade de 3.0L a) supercharged? b) oversized? c) SSI, exhaust and the usual way? 2) Sell the 3.0L, go 3.2 or 3.4 or 3.6? Lemme know your thoughts. Thanks! |
SSIs and a monty muffler will get you 15+ HP, improve the heating, and make it sound real nice, n'est ce pas?
Hi John, already have a Bursh exhaust and my heater system goes very well, merci!
I thought of the usual SSI’s set-up, but between the SSI’s set-up and a 3.2 w/Chip, whats best? Thanks! |
can you get a 3.2 for $4K canadian? not really a huge difference in horsepower between the 3.0 and 3.2, plus 3.2s have valve guide problems, requiring a valve grind, which can cost $3K US. i would keep the 3.0.
Thanks! |
Your engine sounds ok already.
Personally, I would spend the money on suspension improvements and driving school. |
Farleyd,
Perhaps a nice set of performance cams? I have heard that early 911S cams and especially early 906 cams really perk up a 3.0L engine. Since I am an early 911 enthusiast running Weber carb's on both of my cars, I don't know what you would need to do with your fuel injection system in order to switch to hotter cams? |
I would go with the SSI's and muffler. The rest will quickly disappear on fixing all the things that need fixed on a 25 year old car. Things like struts, shocks, rubber bushings.
Blau you can't run cams that wild on a cis car becaust the high over lap cause some reverse pulses, screwing with the fuel metering flap.
I think i posted this before, or it sounds familiar but for that money why not buy one of the cheap turbo bolt on kits. 40-60% increase is some major cojones in that car but not enough to cause other $$$$ mods. |
1fastredsc,
Thanks for the info on hot cams and CIS. Well, here's another reason to stick with the early 911's: Weber carb's. They allow you do many modifications with your engine, without creating major induction problems. |
save the money until you really need it.. and you will!
damn sorry guys, my mom got onto my computer. time to change the password. |
Why not sell your engine and get a 3.6? That should be doable for a 4k difference. But of course, you will have to be the one doing the work! :D 4k is a lot of dough, OTOH, if it comes to messing with the flat 6 it unfortunately isn't that much any more!
I'd stick with SSI and keep the rest for other areas where you might need improvements! G |
| All times are GMT -8. The time now is 12:46 PM. |
