-   -   Engine dimensions (http://forums.pelicanparts.com/911-engine-rebuilding-forum/138772-engine-dimensions.html)
Yaninnya 12-08-2003 08:09 AM
Engine dimensions
What are the following 911 engine dimensions:
1. Lenght from gearbox mounting surface to the crank pulley (inc. pulley)?
2. Overall width?
3. Distance from the middle of the crank to the lowest point of the sump?
Who can help me?
neilca 12-08-2003 09:29 AM
I recently measured from the gearbox mount to the front of the fan pulley it was 20.5 inches. I do not have the other dimensions.
Hope that helps,
neilca
Yaninnya 12-09-2003 04:47 AM
Thanks, neilca! Who else can help with other dimensions?
neilca 12-13-2003 07:16 AM
I got the rest of the measurements. 30 inches wide and 8.5 inches from the center of the crank to the bottom of the sump.
Hope that helps,
neilca
Yaninnya 12-15-2003 02:00 AM
Many thanks, neilca! It is huge help for me. Thanks!
Ups i forgot one dimension: from the centre of crank to the top of fan housing. Could you do it for me one more time?
neilca 12-17-2003 05:20 AM
I will be at my shop on Thursday. I will try to remeber to get that dimension.
Yaninnya 12-17-2003 09:24 AM
O.K. I'll wait. Thanks!
neilca 12-19-2003 05:11 AM
The fan I have is a five blade. I measured from the center of the crank to the highest point on the fan and it was......13.5 inches. This is a lot lower than the four cylinder with the 911 fan.
Good luck,
neilca
Yaninnya 12-22-2003 04:50 AM
Many thanks one more time!
