vash's Avatar
silicone on through bolts...
didnt want to steal any thunder on the 2.7 assembly thread, so i will start another.
doesn't adding silicone sealant or silicone lube on the fastener affect the tension in the bolt? because a slippy-er connection would affect the torque right? you could affectively over-torque the connection. no that is not right, the torque would be correct, but the tension would be over tensioned. right?
cliff
poof! gone
Old 12-11-2003, 10:39 AM
Probably. To lubricate a threaded fastener, use anti-seize compound. Most torque tables assume the threads are lubricated with "regular" lube unless stated otherwise. Anything slicker (moly, silicone, etc.) will cause the tension to be higher than specified.
Using silicone to seal the threads is another matter. Maybe depends on the application. Anything specific in mind?
Sherwood
http://members.rennlist.org/911pcars
Old 12-11-2003, 12:33 PM
vash's Avatar
i was just reading the other thread about the through bolts. it probably is not a big deal because the torque values are relatively low, so the error would be in consequential.
poof! gone
Old 12-11-2003, 12:48 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I found some washers through McMaster-Carr that have nitrile or some such on them.
They are made to seal the hole when tightened under the head of a bolt or nut.
According to the package..they are good for 550 deg F which is the temp for silicone...so I might try them on all the relevent bolts.
Bob
Bob Hutson
Old 12-11-2003, 06:45 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Bob,
I know I"m missing something but Are they beveled like the OE Washers? Otherwise they won't have room for the O ring.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-11-2003, 06:50 PM
HawgRyder's Avatar
They are quite thin...and they have the O-ring sort of built in (bonded) to the metal part.
Like I stated...I'm not sure if I'm going to use them...it's tempting...and they come in all the metric sizes.
I think that in the decades since these cars were designed...there must be advances in sealing that were not available back then.
Bob
Bob Hutson
Old 12-11-2003, 11:40 PM
