A hotter cam would probably give more power, but I want to keep the engine's power band pretty uniform (less peaky). The 'S' cam on the 3.2 is a well-proven combination that gives plenty of low-end torque. -Wayne |
Cost effective? Probably about the same as the other methods, but you can control timing, and you never have to buy distributor caps again. Plus, the system has a good resale value on the market. I have an extra one used, if anyone is interested. I think I want $850 for it (it's an earlier model HPV system). -Wayne |
The JEs are a fine alternative, and can be very reliable too. Also, they are significantly less expensive when doing a rebuild. -Wayne |
As an aside, I got both the 101 projects and the Engine Rebuild book in the mail yesterday, they're great. Nice job on the info, layout, and look. JCM |
Tom |
Thanks Tom I forgot about that. Better refigure my Budget.
Now when they bore out the 95's to 98 do the need to replate?
I have a 3.0 SC twin plug engine with 10.2 comp., ported heads, RSR cams, 46mm Webers, and Electomotive XDI twin plug ignition, 1 5/8 headers with megaphones. Any idea of what kind of power increase I would see by just swapping to 10.5 comp. 98 mm pistons and cylinders to make it a 3.2 short stroke? Are the 98mm cylinders slip in or do the require the case spigots to be bored?
Jacko, how high do you rev this engine, and what kind of fuel are you running?
John, it is in a dedicated race car, and I am shifting at 7400 rpm. I am running 112 Sunoco leaded racing fuel.
I would increase the compression ratio up to 12-1 at least. with the type of fuel you are using you will have no problems and you will get a nice increase in torque and HP. I would also run the car on a chassis dyno with the combination you have now with the 112 fuel. I would also try some 100 or 104 octane. You should see a small increase in power with the lower octane fuel. With 10.2-1 and twin plugs the engine will be fine on 100 octane.
Yes, I want to run it on the dyno, but it hasn't been in the budget. I always worry about reliability when increasing compression ratio.
| All times are GMT -8. The time now is 09:04 AM. |
