The weak link in these things is the rubber tube and fittings.
Rather than buying new lines, can they be repaired by cutting out the rubber line and replacing with some fuel line and compression fittings or even simple screw down ring clamps?
David |
Warren Hall Student
Cam oil lines are about $22.00 for hydralic tensioner set-up and $15.00 for non-hydralic tensioner setups.
You might save $10.00 trying to rig something. Not a good gamble in my opinion.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Author of "101 Projects"
Yes, the lines are very cheap - don't waste your time...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
