-   -   Rod Bolt Problem Help! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/140603-rod-bolt-problem-help.html)
B.Lane 12-21-2003 12:43 PM
Had my rods sized at a local shop. When i gave him my rods i did so with OLD rob bolts. I had some of my new parts in with the box of things i wanted machined. When i got rods back MY NEW ROD BOLTS WERE INSTALLED IN THE RODS TO HOLD HALVES TOGETHER BY THE MACHINEIST. They were torqued pretty darn tight. When i loosen them i need to clamp the rods and use my torque wrench to loosen. I set to 35 lbs before my wrech stopped clickin out. Are these rod bolts trash now or can i still use them? I know LOOSEN torque is not the same as tighen torque but im freaked out by this. Will they stretch under 42 ft lbs? Going in a 82' 3.0. Basicaly, can i use these bolt or do i gotta buy new ones.
Jim Sims 12-21-2003 01:07 PM
If there is any doubt, which there apparently is, buy and use new ones. What is a set of 12? $70 and a few days if one orders them on-line? This is nothing compared to the cost ($ and time) of a connecting rod coming loose. Cheers, Jim
john walker's workshop 12-21-2003 01:36 PM
i'm sure you went with ARP or raceware bolts, so no big deal. they can be reused.
john walker's workshop 12-21-2003 01:40 PM
oops, i got you confused with r.dane, who is building a hot engine. what jim says.
vash 12-22-2003 06:13 PM
wow, is this correct? two different threads with the same topic, from the same area?
Wayne 962 12-23-2003 01:13 AM
Yup, ironic, isn't it...
Same shop?
-Wayne
cstreit 12-23-2003 10:49 AM
One guys lists "Colorado" the other lists "Denver"
Betcha it's the same place...
One wonders how many loose rod bolts are driving around Colorado because this shop already stretched them...
