Porsche Crest 1974 911 project
Hi everyone, I need some Ideas. I have a 74 911 with an 83 SC engine in it. I'm looking to change the engine back to a period correct 74' 2.7, though i want a MFI system. How complicated will this be to do? Is it possible to put a MFI system on the SC? I love new ideas so please don't hold back. Any information would be great.
Thanks,
Erik
Old 12-22-2003, 04:25 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Sure it's possible. What you would probably want to do is at least change the Pistons and cams to something a little more lively. Then find a complete MFI setup (preferably of the S) this would have to include throttle bodies and stacks that are at least 36mm (don't know how much airflow the 3.0 would require). Lastly you'd need to send your pump to someone (pacific fuel injection or Hans) to match the space cam to your engine.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-22-2003, 04:32 PM
Bandwidth AbUser
Jim Richards's Avatar
The engine's left cam will need to incorporate the drive gear for the MFI pump. And, if I recall correctly, the fuel delivery system (from fuel pump to the injectors) of CIS cars is different and will likely need to be converted to what's used in MFI cars.
Jim R.
Old 12-23-2003, 04:11 AM
Thanks for the info guys.....Wouldn't I have to get new heads as well for the 3.0 since they are CIS ones?
Old 12-23-2003, 06:18 AM
Send a message via AIM to fintstone
As most folks seem to prefer the 3.0, just advertise that you would like to trade your SC 3.0 for a nice 2.7. I'll bet you can get someone to take you up on it and do the engine swap for you as well.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 12-23-2003, 07:51 AM
Somewhere in the Midwest
MotoSook's Avatar
Umm.... I can get a couple of 2.7's in a split...and can install it for you after the 2.7 is sorted. If you really want to got to a 2.7 (I'd recommend stating with the 3.0 and putting carbs on it), e-mail me.
Edit: I could use another 3.0 for Super Secret Souk Projects.
Old 12-23-2003, 08:07 AM
drag racing the short bus
dd74's Avatar
Souk and Wayne have a good point here. If the 3.0 is in good shape, stick with it and give a call to PMO. They'll provide all the components necessary for a nice switch from CIS to carbs, and for about $1,500 less than MFI (in parts alone). And because PMO uses fairly "new" Weber componentry (note: "new"), your mileage may be a little better than with old Weber technology.
Regardless, a couple weeks ago, I did some spirited driving behind a weber-equipped 3.0, and man, that car had some guts to it.
The Terror of Tiny Town
Old 12-28-2003, 09:45 PM
