Porsche Crest three.. 3.0 Assembly Questions
Can I get a correct measurement when I do the Deck height ck if I do NOT install the rings first ??? (have the wrong tool ) and second, does the top of the cylinders need to be smooth,.or a little rough ,. mine are slightly rough,.and third..when I do the deck ck and I use my NEW head gasket will it get smashed,.or should I use and old one..
Thanks Frank
Old 01-12-2004, 08:57 AM
Super Moderator
cstreit's Avatar
The rings won't directly affect the deck height obviously, but they do help hold the piston a bit. You may find that without them the piston can rock back and forth inside the cylinder bore and skew your measurements. I typically take measurements from the top, bottom, and sides, then average them together because the piston moves slightly. If I can can the same average after 3 trials, I call it good.
What area on the top of the cylinders are you referring to? The head mating surface? I can be slightly rough like a matte finish, but I would wonder abot a sanded or "textured" finish.
I use the new gaskets when check in the height... They may crush slightly, but I haven't had any sealing issues because of it.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-12-2004, 09:11 AM
Yea ,..I wanted to see how tight the deck height was ..I should install rings first to be safe..and yes the cylinder groove for the gasket seemed a little rough to the touch,.kind sharp when I run my fingers around them...Thanks Frank
Old 01-12-2004, 09:16 AM
Super Moderator
cstreit's Avatar
I did the same "Duh" Wayne, thought he was asking about the base gaskets..
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 01-12-2004, 04:38 PM
Thanks a lot Gentlemen,...Frank
Old 01-13-2004, 07:35 AM
I wouldn't think it would make any difference if you install head gaskets (later CE type that is) when doing 'mock-up' assemblies for measuring etc. I say this because these head gaskets crush into the groove of the cylinder until the head makes contact with the cylinder. Not really adding any height to the assembly..
Old 01-13-2004, 10:09 AM
Ahh Ok I was curious as to how much crush was there once the gaskets were installed ...Thanks Frank
Old 01-13-2004, 11:48 AM
