Are these E or S pistons ?
I know these are not very clear pictures, but they're the best I can do. The motor is a '69 2.0L E, but these look like the S pistons in Wayne's book. Can you tell which they are? Have any pictures of 2.0L E pistons?
Thanks,
Rob
1980sc
Old 01-02-2004, 12:50 PM
They look like "E" domes to me. You can tell for sure by measuring the upper piston ring, I believe it is thinner on "S" pistons. You can also measure the valve pockets as the "S" heads had large valves and deeper pockets due to the cam timing. You could also "cc" the domes but that is a bit of work.
Old 01-02-2004, 02:07 PM
jluetjen's Avatar
Those valve pockets look too shallow for S's. I suspect that they're E's.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-02-2004, 02:38 PM
