Cylinder Head Gasket Set - Missing Orings
Can anyone tell me if the Cylinder Head Gasket Set is supposed to come with the o-rings for the case through bolts?
I just went through all my parts that I ordered from the rebuild wizzard and cant seem to find them. |
I just checked the Pelican Wizard gasket page and there supposed to be in there? Does anyone else have a gasket kit they could look through and tell me if Im missing a package? Its driving me nuts since I was all set to seal my case up and lo and behold I have no o-rings.
http://forums.pelicanparts.com/uploa...1073186464.jpg |
I think it depends on which kit you bought. If it was just the top end kit then I believe the answer is no.
Here's the PP part number if you need it (I had to pick-up one on my last order): K-701-006-40 at 75 cents each. |
Doug,
Thanks for the part number. The reason why I'm trying to make sure that Im not going crazy is because I bought the kit thru the rebuild wizard and it states that the kit I recieved has the through bolt o-rings but I just cant find them. Link to the page: http://www.pelicanparts.com/cgi-bin/wizards/Parts_Wizard.cgi?command=step4&wizard_root=911_eng ine_rebuild H-100-907-03 Cylinder Head Gasket Set, 911SC (1978-83) $148.00 Am I missing a package from my kit or is this a typo on the site? |
I though it was supposed to (seems like the list and pictures on the rebuild wizard show the o-rings) but mine didn't have them either! Had to buy them separately.
The o rings are in the bottom end kit, ie you have to split the case.
If you split the case you should have bought both top and bottom or a complete kit. |
Jack,
Thanks for the reply. I ordered the kit from the rebuild wizard (link above) and it stated that the through bolt o-rings came with the set. I notified Wayne about it and he gave me FREE shipping on the missing o-rings. Which works out for me as he also noted that I was under charged for the kit and the pricing has since been adjusted. |
When I recently ordered a gasket set for the top end of my 2.7 I made a conversation with the Pelican office. I was told that they was an error in Wizard. The head gasket set starts with the prefix C- and the whole engine gasket set starts with a K- prefix. There did appear to be an error in the link between th catalog number and the picture. If I rememeber the difference in price was $194 and $249 for the total engine set.
Simon, if you ended up with the same gasket set I did, you will also find that it doesn't have the flywheel seal, the oil cooler seals, and the #8 nose bearing seal.
Ahhhhhhhhhhhhrhrhrhrhhhhhhhh!
I just got my through bolt o-rings last night and thought that I'd be ziping up the bottom end today then I read Kurts post. My mouth droped open as I ran to the garage. :( No Flywheel seal & No Pully Seal, who knows what else. Im going to have to go through the whole kit over again to make sure whats missing and another call to Pelican. I guess as it turns out I was under charged and under shipped. |
Simon,
Those components are included in the bottom end kit. If you only ordered the top-end kit, you weren't undershipped.... |
"I guess as it turns out I was under charged and under shipped." Sorry, but the mistake this time wasn't on my end - I specifically told you which parts to order in the email I sent you. I have since fixed the Rebuild Wizard so that the complete gasket sets are properly added to your shopping cart. Also fixed that z-block problem... -Wayne |
Wayne,
I put a call in today and spoke to Jason who was waiting to speak to Tom. Could you please tell me what I need to order now to complete whats missing on the bottom end kit since I already purchased the O-Rings? Thanks and sorry for the hassel but I just want to get this motor back together and go for a spin. Regards, |
Your stuff is being drop-shipped overnight - the bottom end gasket kit you need will be there tomorrow so you can assemble the engine over the weekend...
-Wayne |
Wayne,
Thanks for getting me all straightened out! This is the type of Service that keeps me coming back for more (as soon as my wallet recovers). :) |
Oops, sorry I couldn't find my notes on that call. I guess it was an H prefix not a K as I had mentioned.
...and thus concludes today's story about why we order from a reputable supplier instead of the unending list of other choices. :)
| All times are GMT -8. The time now is 09:25 AM. |
