82 SC: Which wires go where?
82 SC
I bought the car with the engine in boxes. I've rebuilt the engine and now I need to figure out which connector goes where. The connectors are faded to the point that I can't tell the colors (might be green, might be blue) or are missing all together. Does anyone have a source for which color wire goes where? I've figure out most of them but I need to know which color wires go to the: 1) Throttle Sensor plate 2) Throttle Position Sensor 3) Cold Start On a couple of the wires, I'm missing the connector so I have to create a new connector for them. I appologize if this is documented previously. I did a search and didn't find exactly what I'm looking for. All help appreciated. If I can get this figured out, I can get it into my car and fired up. Michael |
Have you looked at these diagrams?
SC Wire diagrams |
green connector to sensor plate, blue one to cold start valve, short black to throttle switch, gray to warmup reg, long black to air reg.
Excellent. Exactly what I needed. Thank you very much. Install happens on Sunday. That will be the test on how good Bentley and Wayne's books are (or maybe how well I can follow instructions).
Michael |
-Chris |
| All times are GMT -8. The time now is 06:41 AM. |
