Flywheel wornout?
Specs in Wayne's book say that the 930 flywheel for the turbo should be min of 9.9mm. Mine is at 10.59, how many miles would I get from this or should I just replace it.?
Also it is not the stock flywheel but appears to be a "Patrick" brand. |
If it's in spec, then keep it - flywheels don't wear very much unless you ride the clutch all the time...
-Wayne |
Thanks Wayne, how important is having it "resurfaced"
-Wayne |
| All times are GMT -8. The time now is 09:54 PM. |
