Leak from rear main seal
I just started up the new 3.2 Short stroke that I just completed and got a fairly substantial puddle of oil from the rear main crankshaft seal area. Enough that is clearly under pressure (a light stream, more than a drip)
Since it is under pressure, I'm assuming the failure is the seal itself and not the o-ring yes? (After looking at an old nose bearing, it doesn't look like the o-ring seals the pressurized oil......rather it seals in the case oil. Is this logical? |
Yes it is. Your seal might have gotten pinched on the install. It's a relatively easy fix though...
-Wayne |
Thanks Wayne... I am hoping that it's just that seal or the layshaft cover gasket. Don't want to split the case again. Simple enough to drop the back of the motor down and fit a new one.
Technically, that's a front seal even though it is in the rear of the car. It's the front of the engine. Sorry for being so picky.
I too hope you can fix this leak without splitting the case. |
Front seal? Why would that be the front?!
Thanks for the well wishes... I've got the suspension completely rebuilt/refurbished, motor should be bearly done... Just need to take care of the bodywork now... |
Chris,
Partial engine drop and a new pully seal are fairly easy, heck I even did that successfully ;-) You might want to run an emery cloth around the lip to ensure there are no notches that could tear the new seal. |
I'm not worried about that seal and the work... Can do the whole job in less than an hour. With the wide open race motor compartments I can do a clutch pull and replace in 2 hours by myself. :D
My biggest concern was the o-ring. I was VERY careful not to pinch it and lubed it well, but of course, since that's the worst case scenario I started worrying. I'll replace the FMS today and see what happens. This is just lowering the back half of the motor... No biggie.. |
FIXED!
Seal was torn ever so slightly where it rides on the crank. Thanks. 3.2L Short stroke rides again! (After 2 years and coming to be in about 15 boxes... :D ) |
| All times are GMT -8. The time now is 02:28 AM. |
